Hello all,
I have what seems to be a bit different than any other issue I can find.
I have an '88 325is. I purchased this car about 6 months ago and have done no major work to it. A couple days ago I noticed that it was running hot. To date the car has run mid gauge until this incident. I have spent a couple days researching possible issues and talking to the local BMW guru. This evening I did a driving test and here is what I found.
I fired the car up cold and let it idle. The temp would not move much above the blue.
I started to drive and within a few minuted it was right at the bottom of the red. The gauge has not actually gone into the red but seems to like to live just below it.
Going up hill the car ran right at the bottom of the red. Coming back down the hill (several miles long) it seems to stay in about the same spot just below the red. The only way I can seem to get the car to cool a bit is at about 20mph with the heater wide open. Even at that it only comes down about half a notch (Less than 1/8th of the whole gauge).
Since I couldn't get the the car hot at idle I let it idle for a few minutes in the driveway bit it would not come back down.
When I popped the hood here is what I found.
It wasn't low on coolant.
Not gushing anything.
No coolant in the oil.
I opened the purge bolt and coolant came out pretty quick (you could say squirt).
It has never pushed out steam that I know of.
The top hose was hard.
Top Radiator hose hot - bottom hose cold. Not Less warm, cold.
The top of the radiator was hot - the bottom was cold.
My initial feeling is clogged radiator. I've never really seen a problem like this before but before I go tearing into anything and diving into the money pit I thought I would consult the experts.
Any and all input it much appreciated.
![Roll Eyes (Sarcastic) [rolleyes] [rolleyes]](/images/smilies/rolleyes.png)
