Ok so it was time to replace my 99 M3 convertible's battery. I browsed through previous messages here on another bmw board and several posters suggested that they had gone with Diehard International Group 48 battery.
Well, I brought home the same today and tried installing it.
Well, this battery is shorter than the stock and so I cant make the positive cable reach the +ive node on the battery. If I slide the battery toward the positive cable, then I cant tie it down with the nut/screw since the nut/screw hole is on the -ive side (on the battery pan) of the battery.
What is my option here? I guess I can try Interstate MTP-91 with a vent kit or something?
Thanks in advance...
-KG
-KG
![Wink [;)] [;)]](/images/smilies/wink.png)
