Hello my fellow Bimmers,
I would appreciate your input on a few things based on your experiences:
1. The Ball joint Bracket attached to my tire on the front passenger side of my 1996 328i is shot according to my mechanic. The ball joint itself is lose and causes about an inch of play from side to side when the car is on the lift and you push on it. Has anyone had this problem? How did you fix it? It just needs to be replace correct?
2. The ball joint problem has caused uneven wear on the tires. Is it not recommended to replace just the fron tires if they are about twice as worn as the back?
3. Last night I was driving with the AC cranked. I put my car in park and my wife waited while I ran inside the store for about 3minutes. I came back and my car was overheating. I stopped at a gas station put a quart of 5w-30 in it and also some additional coolant (it was not empty, but needed to be topped off). It was hot enough to fry an egg on the engine when I popped the hood. I drove it home with the heat cranking and it was fine. I then put it in park with the engine running for about 2 minutes and it had overheated again.
I just paid the car off, and as soon as I paid it off all these problems began of course
. It has about 116,000 miles on it and I am just trying to decide if after I make these repairs I should sell it (probably could get 8-10k for it) and have a nice fat downpayment for a newer 99-00 ish model. However, this would result in monthly payments again of probably about 200 a month. (trying to minimize expenses right now as I am in the second year of running my own company. If I have to keep fixing things each month then I might as well get something that will not need as much repair, even though it might cost me 200 or so a month...hmmm...thoughts?
Thanks!!
Thanks!!
