Hello, Another question. I have a 93 325I with 98000 miles. I found out that the throw out bearing is going bad because of the noise it is making. The car is in great shape so i talked to a mech and he said not to worry right now, they dry out and make noise. (Is this True)? If i replace the bearing i will surely replace the clutch too. One other thing once the car warms up the idles surges whenever i depress the clutch pedal, then it goes back to normal idle if i let the clutch out. Is there a sensor somewhere that needs replaced? or will this go away once the clutch is replaced.
thanks again
thanks again
![Big Grin [:D] [:D]](/images/smilies/biggrin.png)
