I was wondering if anyone else experiences a gas spill/leak/drip when the tank is completely filled.  This is the second time I started smelling gas n the cabin when the tank was full and when I checked there was gas dripping from the bottom of the tank... just curious if this is at all dangerous.  Also, how do you reset the yellow "CHECK" light that keeps flashing.  I believe its related to the 02 sensor and I just had it replaced.
Thanks my car is a 1991 325ix ... and it would be helpfull if someone knew the correct bentley service manual I should get for my car. (So I won't continue to ask annoying questions.
 .  I've pin pointed it to the hose going to the fuel filter...but I gotta finish the handbrake install (PITA) before I start ripping off panels to get a closer look.
