there are only a couple places where the centre console are attached to the driveshaft tunnel;  open up, and remove the rear ashtray, you'll see the nut.  remove the shift knob and Ebrake handle, and open and remove the front ashtray.  there are two screws to take out in the compartment under the heater controls where you put your cellphone/ sun glasses / cigs, etc... take those out... that'll get everything loose, you'll be fine after that... take the window switches out, and you're pretty much done.    The door panels (haven't done these in a while) basically pry off... start at the bottom, remove the "holy $hit" handle and the surround for the door latch... unscrew the lock knob...  MAN, I kinda forget how to do E30 stuff when I haven't seen it in two months.  Help me out Justin.
