I am having a problem with my BMW 325i overheating.
While driving above 80 kilometers it has no problem for about two hours then the coolant is empty. When stopped it quickly goes to the red. Having a problem with over heating. with a 325 I BMW.
The car runs great on the autobahn or driving above 80 Kilometers it stays in normal heating range. While stopped or driving below 80 it quickly goes into the red.
I have refilled the coolant and as soon as I drive 5 kilometers it is empty. I noticed while parked and letting the engine run that it was dripping from a valve that was connected behind the fan on the fan assembly.
Any clue
Any ideas. I am thinking that maybe the fuse or hermastat is out. The fan turns, but its not circulating the coolant.
Any clue
thank you all for your help. the water pump was the problem. To bad a didn't ask about bleeding the coolant system. My fault. Thanks
