How do I reset my "check engine" and "brake pads" indicator lights on my 1993 325i? Can I just disconnect the battery, or do I need a special re-set tool?
Also, what reasons does the "check engine" light go on? I've changed the oil, air filter, all fluids, cleaned fuel injectors, etc. but the indicator light is still on! Thanks in advance for any help.
Take care,
Mike
Take care,
Mike
I think you need to replace the censor when you replace the pads...
