Fronts:
- Bentley says to completely remove the rotor/caliper assembly from the wheel plate. You do not have to do that BUT you must be very careful not to damage the joints. The problem is that the rotor/caliper/wheel plate is heavy and letting it flop down will damage the ball joints.
- I suggest the following sequence: loosen (don't remove) the two bolts that hold the strut to the wheel plate. They are very tight, if I remember correctly they have Loctite on them, and you are supposed to reassemble with Loctite.
- Loosen the upper nuts
- Plan on a way to support the hub assembly. I used a combination of blocks on the bottom and wire from the top.
- Remove the bolts/nuts completely and pull the strut out.
Now you can work on the strut:
- Try to keep dirt out of the upper bearing as you work on the strut.
- As you know you need a spring compressor. If you use the "long screw" type, grease the threads of the long screw to make it turn a bit easier.
- Mount the strut in a vise or other secure location. I use a Workmate type work table.
- Once you start compressing, NEVER EVER put your face/head any where near or over the end of the strut. If something lets go, it would be ugly.
- After the strut is compressed sufficiently, loosen the top nut. The top nut that secures the piston shaft to the upper plate is usually a pain to loosen, because it is fairly tight and the piston shaft spins when you try to loosen the nut. The trick is to use an air impact wrench and blip it a few times. The quick blips spin the nut before the shaft can turn. Again, be safe, the compressed spring is packing some energy.
- Assembly is pretty much the reverse. I had some a couple of trial and error issues with the new springs and compressor placement. After I compressed the new springs, I had the clamps in the wrong place and I could not remove the tool. If you use the more expensive clam shell compressor, you may not have this problem.
- When you tighten the top nut, you might be tempted to hold the shaft with a vise grip. Do not damage the piston (grip marks, etc.) or it will tear up the piston seal. Koni warns to NOT use an air wrench to tighten the nut.
- The dust cap that goes over the shaft at the upper plate will not fit - the adjustment tip sticks up to high. I solved this by gently heating the center of the cap with a butane lighter and pressing a socket extension on the inside to slowly stretch the dome. I can't figure out why Koni didn't include a new dust cap. I have seen a lot of people just leave the cap off, but the bearings don't like dust and dirt.
Good luck!!!
