Hello All
I have two problems with my car
1: Sometimes the car won't turn over or you turn the key and it starts with a delay.
If it does not turn you walk away for 15 min and it starts up?
2: Also the A-C blower fan speed is very weak at times specialy if the outside temp. is greater then the setting on the A-C control. as soon as you change the setting on the control higher then the outside temp. the fan kicks in real strong.
Any ideas?
Thanks Heinz
Any ideas?
