I've got a lot of work that I'm going to be doing on my car in the next few weeks.  Before now I've only had to jack my car up twice to change the oil and do the pads.  I know that if I'm just going to be working on the engine the easiest thing to do is get some ramps and just drive the front end up, but that doesn't work for changing the oil or coolant or any fluid really because the car needs to be level for it to all drain out.  Before when I changed the oil I used a floor jack to jack up the car and put 4 jack stands under each of the 4 jack points but this takes a while and I'd like to know if theres a better way before I go out and buy a new jack and 4 stands.
I'm thinking that a combination would be best. Say, drive the front of the car up on ramps and then jack the rear end up and put it on jack stands. That seems like the easiest and fastest way since you have a singular jack point in the rear of the car. My worry is, however, that the car might shift or fall since you can't use the parking break or transmission lock on the front wheels and I would be taking the pressure off the back wheels to lift the car. But if the car is at the top of the ramp and it's level, it shouldn't roll back, correct? Is there any safe way to do this? How about if you put wood wedges on the ramps to stop the wheels? Any better way to do this?
Ok - sorry for the long post, and thank you for your responses.
P.S. - Is there a single center point under the front of the car that you can use to safely jack up the entire car, like a crossmember or something? I know there is in the back but I'm not sure about the front, I've just always done each side individually.
