My car has been a pleasure driving. I do all the routine maintenance (oil, sparks, etc.) and haven't had any major problems. For a car with 200k miles
, I think i'm overlooking a lot of factors. What do you guys think I should do? Here are a couple of problems i've had in the past 3 years...
1. Car ran outta oil about 3 years ago. Heard loud ticking sounds at startup and when I checked the stick, it was completely dry. Funny thing is, the "check oil" light didn't come up.
I've been using synthetic ever since. However, at initial startup, ticking sounds can still be heard for a few seconds but would eventually go away. Is this normal?
2. In dire need of new tranny. Scares the living @#$% outta me when 1st gear pops out. Constant rear clunking noise also becoming a nuisance. Suggestions?
3. Recent smog check revealed an abnormal amount of hydrocarbons. Bad cylinder?
4. No error codes!!! Tried the trick but to no avail. Computer problems?
5. Bought a dinan chip model D900-2550 E; 623D; Card E.O.# D-176-8. My car's ECU # is 0 261 200 413. Brought to dealer to install and said wrong one. Wasted $$$. Recommendations?
6. Ok I'll STFU now
. Thanks again. Hope to post pics soon.
, I think i'm overlooking a lot of factors. What do you guys think I should do? Here are a couple of problems i've had in the past 3 years...1. Car ran outta oil about 3 years ago. Heard loud ticking sounds at startup and when I checked the stick, it was completely dry. Funny thing is, the "check oil" light didn't come up.
I've been using synthetic ever since. However, at initial startup, ticking sounds can still be heard for a few seconds but would eventually go away. Is this normal?2. In dire need of new tranny. Scares the living @#$% outta me when 1st gear pops out. Constant rear clunking noise also becoming a nuisance. Suggestions?
6. Ok I'll STFU now
