If nothing else was touched, I would first double check the ECU number for the right chip.  There are several different chips depending on the year ECU. Reinstall stock chip.   If it runs better then I would call the vendor, explain the problem, and they may have encountered this before and can tell you the solution.  They will also offer to send you a new chip with return of the old one.  The program has not been changed and has been around for years.  The chips are waranteed for life and the vendor (Turner Motorsport in my case) will offer to replace it at no charge or offer you a refund.  I have the JC chip in my '89 for over a year with no such problem.  My problem is the 91 octane gas I have here.  It is not high enough for summer performance driving.  I run a 25% mix of unleaded 100 octane for the summer for best performance.
