Hi all, I drive an 87' 325is
I've been having trouble with my fuel, I think. I had trouble passing DEQ because of too many unburnt HCs, I can smell unburnt gas when the car starts and for a while after, and I've been only getting about 22 mpg on the freeway. I took it to a mechanic to get it to pass DEQ and he said it was a problem with the pump or regulator. I checked the charcol filter valve, its ok; and I wanted to check the pressure regulator but the method for testing shown in my Bentley manual is based on the pressure from the Cold start valve, and my 87 doesn't have a cold start injector (from what I understand). Is there another way to test?
Now that I think about it I should probably try testing the fuel pump, duh
, but still I'm interested in what you guys think.
thanks in advance
thanks in advance
