My girlfriend drives an '87 325i.  I just put the snow tires on it (195/65r15), and she's complaining of a wobbly steering wheel at around 80-90km/h which didn't happen with the factory rims.  The front tires are balanced, and should be fine (they're almost new).  What I'm wondering about is the steering rack.  There is a little bit of play in it, meaning that I can move the wheels back and forth a little bit, which I suspect is causing the wobble (and slight pull).  The power steering is not evident when turning the wheel when parked, and only seems to work if you give it some gas while turning.  So, I'm assuming that if the belt is tensioned right,  that must mean the pump is tired (but doesn't whine), but would that account for play in the steering rack?  There's no play in the lower ball joints, no fluid loss, so is there any way to repair play inside the steering rack?  The other thing I'm wondering about, is that if the play in the rack is too little to notice, could the way the rim seats to the hub be the problem.  I'm not using any hub rings to space the wheel properly, and I'm using factory bolts on aftermarket rims (round bolt base instead of tapered).  What the hell am I asking????  I guess the steering rack... can they be repaired, and do pumps get tired without making any whining?
