Selavia
             After Your Update I Now Beleive Your Problem Is In The Instrument Panel Electrical Feed. To Check Your Connectors You Have To Remove The Instrument Panel From The Dash. First Have Your Stero Activation Code Handy You Have To Remove Your Steering Wheel.  Disconnect Your Battery Wait About 10-15 Min Before Removing Your Steering Wheel
1.  Set The Front Wheels In The Stright-ahead Position And Released The Steering Lock By Inserting The Ignition Key.
2.  Remove The Steering Column Cover One Screw At The Bottom Of The Cover.
3.  Disable The Air Bag System, Unplug The Orange Connector Under The Steering Column And The Connector From The Contact Ring.
4.  Loosen And Remove The Two Airbag Retaining Screws From The Rear Of The Steering Wheel.
5. Remove The Airbag Module Keep The Trim Side Away From Your Body And Place It On The Bench/back Seat Have The Trim Side Facing Up.
6.  After Removing The Airbag Module, Remove The Steering Wheel Retaining Bolt.
7. After Removing The Steering Wheel Retaining Bolt(but Before Removing The Wheel), Mark The Relationship Of The Steering Wheel To The Steering Shaft.
8.  Lift Off The Steering Wheel Note The Location Of Pin On Top Left On The Column:when The Wheel Is Installed Again,make Sure That This Pin Engages In The Hole In The Contact Ring On The Backside Of The Steering Wheel.
9.  Loosen And Removed The Retaining Screws From The Top Of The Instrument Panel And Carefully Withdraw The Panel From The Dash.
10.  Inspect The Electrical Connectors From The Cluster.  Some Of The Clusters Connectors Have Locking Tangs On Top That Must Be Pried Open With A Small Screwdrivers Before They Can Be Unplugged.
11. Installation Is The Reverse Of The Removal Reconnect The Battery And Check The Operation Of The Panel Waring Lights To Ensure That They Are Functioning Correctly.
                                                      Good Luck
                                                        Jus-n-5
